is there anyway to get serial number of harddrive?
I want to create an application which should work only on certain computers and for that I want to get hard drive serial number.
Do I have any other option?
Thanks.
Sheetal
Thanks.
CVI 2010
LabVIEW 2011 SP1
Vision Builder AI 2011 SP1
(3,048 Views)
There really is (IMO) no good option for this.
Using Win API (kernel32.dll) for can find a function called GetVolumeInformation which will give you the Volume Serial Number, but this should be avoided if you can help it as every time we format the same hard drive, a new Volume Serial Number is generated. What you would really want is the Manufacturers Serial Number for the hard drive but thats much harder to get. You have to use a WMI (Windows Machine Interface) in order to get this.
(3,045 Views)
