LabWindows/CVI
ist it possible in CVI to switch instruments to dummies, so that no real hardware is necessary and commands/results are written/read on the screen
That is a function of the IVI engine and the IVI driver for our hardware.
You will have to set up your 'Virtual Instruments' in MAX under IVI Instruments and Logical Names'. When you install the IVI driver it will set up some "dummy" instruments for a meter, scope, switch etc.
You can use these to see how to set your's up.
They only have classes for meter, scope, switch, power supply and function gen.
You will have to make ALL your calls through the IVI engine for it to work.
Omar
(2,840 Views)
