LabWindows/CVI
label/value pair for ring control populated dynamicallly from database column
Hi All,
I have a ring control in my UI which I have to populate dynamically from columns obtained from MS SQL database. I can obtain the result from the database and read row by row. So do I create an array with label/value pairs and pouplate the ring control using InsertListItem ? or is there any better way of doing it ?
Kanu
(3,076 Views)
Accepted by Kanu
I'm not aware of a method to populate a ring control other than looping through your array and calling InsterListItem for every array element.
(3,075 Views)
