labwindows 2.2 library functions not found.
I need to maintain an old test system. It uses labwindows 2.2 and Microsoft C++ 7.0 (circa 1993). Nether the linker nor I can find the following functions.
_SCAN_Op, _AI_Config, _SCAN_Demux, _DIG_Prt_Config, _Time_Str, _AI_Read, _ScanIn, _Timeout_Config, _DIG_Out_Line, _ReadLine, etc.
I have used grep on and pointed the compiler to the files in the following directories \LW\LIBRARY, \LW\INCLUDE, \NIDAQDOS\Lib (nidaq 4.6.1f5), \NIDAQWin95\Lib (nidaq 5.1) with out resolving the missing functions.
I have tried every thing I can think of.
What do I do now?
Thank You
Ed Benjamin
(3,214 Views)
I used to write in that version, however, the files have long snce dissapeared. Earliest I have now is 3.1 LW..
Sounds like the daq version is too modern. Except for the _ReadLine call. I do know that the SCAN_OP was fairly new in 1993 if it existed at all.
Let me know how I can help. Is it possible to update the software and substitute the calls with new ones?? Might take awhile, but be worth it.
(3,214 Views)
Hi:
Thanks for your offer of help. As it happens i solved the problem by booting from the win98 startup disk and all worked well. If I booted into win 98 command line mode or tried to run things from a win 98 msdos prompt I got the results I asked about.
again Thanks
Ed B.
(3,214 Views)
Hi Ed Benjamin
I am facing a problem which is very similar to yours, could you let me know how to contact you so I could learn how to deal with this problem. Thanks for your response in advance!
My email is: xxua@sfu.ca
(3,214 Views)
