1)° Is it possible to use Labwindows RT with the PCI-7030/6040 RT system (a processor noard 7030 with a DAQ borad 6040)? I use Labwindows RT 8.5 and the version of the DAQ driver is the 7.4.4.
I read some documentation which explain that this RT system support DAQ driver 6.5.2 or greater.
I wonder if the programmation for this system with Labwindows is possible, because it's an old RT system and I wonder if it doesn't work only with Labwiew RT
2°) If the answer of the first question is yes, Can anybody confirm that to make a programm which realize an acquisition (One shot Analog input), I must Use the followings functions :
- AI_Configure
- AI_Read
- AI Check
Notify that this RT system doesn't support DAQmx...
