LabWindows/CVI
labwindows RT 7030/6040
1)° Is it possible to use Labwindows RT with the PCI-7030/6040 RT system (a processor noard 7030 with a DAQ borad 6040)? I use Labwindows RT 8.5 and the version of the DAQ driver is the 7.4.4.
I read some documentation which explain that this RT system support DAQ driver 6.5.2 or greater.
I wonder if the programmation for this system with Labwindows is possible, because it's an old RT system and I wonder if it doesn't work only with Labwiew RT
2°) If the answer of the first question is yes, Can anybody confirm that to make a programm which realize an acquisition (One shot Analog input), I must Use the followings functions :
    - AI_Configure
    - AI_Read
    - AI Check
Notify that this RT system doesn't support DAQmx...Smiley Wink
(3,150 Views)
This hardware isn't even supported on LabVIEW, so It is neither suported in LabWINDOWS/CVI RT.
It doesn't mean will not work (But i really think it won't)
Richard Keromen
(3,113 Views)
