LabWindows/CVI
labwindows cvi linux evaluation
Hi there,
Is there an evaluation version of Linux run time?  How can I get hold of it? Thanks
(3,388 Views)
  unfortunately not. Since the development is done under Windows and LabWindows/CVI requires activation under windows, and the actual build and final debug is under Linux (through cvicc), then an evaluation version would have to be of the compiler, but you'd already know what you were developing under the initial Windows development so there's no need for an evaluation version for Linux just for the compiler.
Your best option for a demonstration would be to talk to your local field based engineer who could then arrange to come in and show it to you and discuss any fine details you might be interested in.
For the UK, please call in on 01635 572410 and ask to speak to the engineer who looks after your area.
Sacha Emery
ATE Systems Engineer
National Instruments UK and Ireland
// it takes almost no time to rate an answer Smiley Wink
(3,382 Views)
