link issues with external compiler
when I try to compile my source with an external compiler, I do get various warnings and errors.
One is
"mbsupp.h"(29,1)   (29): error: invalid redeclaration of type name "size_t"
"mbsupp.h"(29,1)   typedef unsigned int size_t;
This include file mbsupp.h is included by ansi_c.h, because in my source, I have the following
#include <analysis.h>
#include <ansi_c.h>
#include <cvirte.h>
#include <formatio.h>
#include <userint.h>
#include <utility.h>
So now the important question, how do I resolve this issue? Do I have to change the order of some included files?
Wolfgang
Message 1 of 9
(6,781 Views)
Hello Wolfgang
For this looks like a problem related to the external Compiler used here. I tried to compile a simple Sourcecode with these include Statements using Microsoft Compiler and it was working fine. So witch specific Compiler do you use?
Like you already suggested, its worth a try to change the order of the include files. For example place ansi_c.h at the en.
Another option may be to add a IF Statement in the "mbsupp.h" to avoid redeclaration.
Regards
Moritz M.
Message 2 of 9
(6,748 Views)
Thank you, Moris M.,
yes, the problem is related to the external compiler, it works fine with CVI. The external compiler is the Intel icl 11. I will try the include permutations as suggested.
Wolfgang
Message 3 of 9
(6,732 Views)
Hi all,
I have tried rearranging the sequence of include files, with no success.
But actually I am wondering why the following code is included in mbsupp.h:
#ifndef _SIZE_T_DEFINED
#define _SIZE_T_DEFINED
#endif
The problem with these lines is that the Intel compiler is complaining about the invalid redeclaration of size_t
so here is my question:
Obviously, using the standard CVI compiler, this declaration does not cause any problems, so it might be related to the fact that the intel compiler is both a C and a C++ compiler. Did anybody using any external C/C++ compiler experience (and solve) this problem?
Since the use of Intel compilers is sort of supported by NI I am wondering if someone is familiar with this topic? Hopefully 🙂
Thanks!
Wolfgang
Message 4 of 9
(6,684 Views)
It is possible that the Intel compiler already has its own internal definition of size_t and is therefore confused by the typedef. If so, you should easily solve your problem, by including the following line in your source file, before all the #includes:
This will stop the subsequent typedef from being compiled in error. Or, it may be something else...
JR
Message 5 of 9
(6,682 Views)
Hi JR,
thanks for your suggestion! However, it does not solve the problem, it only modifies it...
1) In case I am using the CVI compiler, I end up with a missing parameter type (of course), so obviously some more refined macro is required; how could one distinguish between an internal and an external compiler?
2) For the Intel compiler, compilation now works, however I end up with a link error
 Undefined symbol '_main' referenced in "c:\program files (x86)\national instruments\cvi90\bin\Msvc\cvistart.lib".
Maybe you have an idea how to solve this, too?
Thanks, Wolfgang
Message 6 of 9
(6,673 Views)
There is a pre-defined macro which can be used to determine if you are in a CVI compilation or not - like this:
#ifndef _CVI_
#endif
Not sure I can help much with the link problem - it seems to have found the library file (usually the problem in similar circumstances is a missing file) but perhaps you need to select between the VisualC and BorlandC library compatibility modes? I've never experimented with an external compiler so I'm not aware of any common pitfalls.
JR
Message 7 of 9
(6,667 Views)
Accepted by Wolfgang
OK,
I have resolved the isssue...
First, I have installed a newer version of the compiler, 11.1.035 instead of 11.0.61. Second, I have chosen a different compiler (Intel offers both 32 and 64 bit and Itanium), obviously now the correct one, because I have the feeling that this caused the trouble.
Anyway, thanks to all contributors!
Wolfgang
Message 8 of 9
(6,666 Views)
Hi JR,
Many thanks for your information on the macro - obviously your answer appeared while I was typing my solution... 🙂
Wolfgang
Message 9 of 9
(6,659 Views)
