‎10-02-2007 05:08 AM
‎10-02-2007 01:39 PM
‎10-07-2007 05:38 AM
Thank you for the answer. There was a problem with one of the lib's included in the project.
I recompiled the lib and it's ok now
‎02-04-2009 06:07 PM
I am having the same problem. What lib did you have to recompile?
Thanx,
Jerry
‎06-05-2009 11:03 AM
‎06-05-2009 12:42 PM
Which version of CVI are you using?
Are you using only source files to build your project, or are you also using .obj or .lib files? If you're using .obj or .lib files, did you build them yourself with CVI, or were they created with some third-party compiler?
Luis
‎05-07-2010 12:34 PM
I am having the exact same problem, but only when do a release build. The debug build works fine.
Errors generated when performing a 'release' build'
clear_history_ecu_data.prj(Release) - 4 link errors
Undefined symbol '___CompiledDebuggingLevel' referenced in "c:\program files\national instruments\cvi2009\bin\msvc\cvistart.lib".
Undefined symbol '___PtrInfoFixupTable' referenced in "c:\program files\national instruments\cvi2009\bin\msvc\cvistart.lib".
Undefined symbol '___CVI_Sections' referenced in "c:\program files\national instruments\cvi2009\bin\msvc\cvistart.lib".
Undefined symbol '___UFRNameTable' referenced in "c:\program files\national instruments\cvi2009\bin\msvc\cvistart.lib".
I am using CVI 2009.
I have deleted the build folder and marked all for recompile.
Any suggestions?
Thanx,
thefalk
‎05-10-2010 10:35 AM
thefalk,
This issue is already being actively worked on here. It would be best if we can keep the discussion to one place so we can easily track the progress and get you a quick and correct solution.
