LabWindows/CVI
.m files to LabVIEW?
Is it possible to import .m files of Matlab,  directly in to LabVIEW?
(4,137 Views)
You should post that question to the LabVIEW forums instead of the CVI forums.
Best Regards,
Jonathan N.
(4,123 Views)
Hey ITA,
You can use the MathScript node for similar functionality.  This is described here:  Developing Algorithms Using LabVIEW MathScript: Part 1 – The LabVIEW MathScript Node
Also, the MathScript Node also describes this application.
(4,079 Views)
Thanks a lot!
(4,069 Views)
(4,062 Views)
