LabWindows/CVI
mesure fréquency 1 ppm
I want to measure the frequency with a resolution of 1 ppm
is that with the card NI6624 and  NI-DAQmx I can measure the frequency?
thank you in advance
Message Edité par aymen1 le 12-14-2008 03:44 PM
Message Edité par aymen1 le 12-14-2008 03:45 PM
(3,379 Views)
As you can see in the NI 6624 Specifications, the base clock has an accuracy of 50 ppm, so I don't think you'll be able to have a resolution of 1 ppm.
Message Edité par Maxime MULLER le 12-15-2008 04:53 AM
(3,364 Views)
