Hello checkers
Thanks for giving us this sequence of steps. Based on these steps, we've beeen able to reproduce the problem in-house, and we are currently investigating a fix which will be included in the next version of CVI. The reason that this has been hard to reproduce is because in addition to these steps, a couple more factors seem to be necessary:
1. CVI has to start up already maximized.
2. You have to minimize CVI from the task bar button, and not from the minimize button in the titlebar of the window.
If we follow these requirements, with the steps you mentioned, then we are able to reproduce the problem consistently (for the first time, I might add).
One thing I would ask at this point, would be that if you (or anyone else) can reproduce the problem in some other circumstances, or even if you can reproduce it by removing one of these requirements, to please post the detailed steps here, so that we can make sure that we address it.
Thanks again,
Luis
NI
