LabWindows/CVI
missing prototype
I wrote this simple callback function and when I compile the program, it gives me an error that I am missing prototype for Test1() even though I included its .h file that has prototype of this function. If I put the #include for Test1.h first in my source file, the compiler complains about the prototype of Test2() and vice versa :
int CVICALLBACK timer (int panel, int control, int event,
void *callbackData, int eventData1, int eventData2)
switch (event)
case EVENT_TIMER_TICK:
if(g_Test2)
Test1();
if(g_Test2)
Test2();
break;
return 0;
Thank you in advance!!!
(3,390 Views)
The problem was solved. I was not using unique pre-processors in test1 and test2 files.
(3,387 Views)
