LabWindows/CVI
type mismatch error
when i was trying to call the function CA_VariantGetChar(&MyVariant,&ch);i am getting run time error as type mismatch (return value == -2147352571 [0x80020005]). pls help me out in solving this error so that i can copy text available in MyVariant copies into ch.
Variable declared: VARIANT MyVariant; char ch;
raj
(4,058 Views)
This Knowledge base is for VB, but anyway, does it help? http://digital.ni.com/public.nsf/allkb/8800DECF0D358C9D86256B1700656C04?OpenDocument
(4,030 Views)
i am working with labwindow/CVI.I am trying to read the content in the a cell of an excel sheet. i am getting the above error when i am trying with the below code. pls help me in solving this
for (i=0;i<ROWS;i++)
          for (j=0;j<COLUMNS;j++)
            // Ask for the ith by jth value of the range which returns a dispatch to a new single cell range
            error = Excel_RangeGetItem (ExcelRangeHandle, &ErrorInfo, CA_VariantInt (i+1), CA_VariantInt (j+1), &MyVariant);
            if (error<0) goto Error;
            // Get the DISPATCH pointer
            error = CA_VariantGetDispatch (&MyVariant, &MyDispatch);
            // Create a new Range Object from DISPATCH pointer
            error = CA_CreateObjHandleFromIDispatch (MyDispatch, 0, &ExcelSingleCellRangeHandle);
            // Get the value of the Single Cell Range
   error = Excel_GetProperty (ExcelSingleCellRangeHandle, &ErrorInfo, Excel_RangeValue2, CAVT_VARIANT, &MyVariant);
     error = CA_VariantGetChar(&MyVariant,&ch);
            // Free Variant element
            CA_VariantClear(&MyVariant);
            //Free Range Handle
            ClearObjHandle (&ExcelSingleCellRangeHandle);
            printf("%c ", &ch);
        printf("\n");
(4,019 Views)
A couple of ideas are coming to my mind in this discussion.
First of all, you do not tell us how ch is defined: this is a relevant information as the error is a 'type mismatch'; its absence prevents us to understand what is happening
Additionally, CA_VariantGetChar expects to read a single char value out of the variant, i.e. a single character. It seems difficult to me that an excel cell returns a char instead of a string: if I were you I will try to understand which data type is stored into the variant with CA_VariantGetType or at least CA_VariantHasChar and operate consequently using the proper function and data type. I personally would expect that the variant stores a string instead of a char.
(4,014 Views)
