LabWindows/CVI
multiple ethernet (client) ports
I am trying to create a LabWindows program that will run on a pc with 4 ethernet ports. I want to use one of the ethernet ports to connect to the outside world. I want the remaining three ethernet ports to be clients each with a dedicated server attached to it (our proprietary boards). But whenever I try to execute ConnectToTCPServer() it only tries to connect through one of the ethernet ports. How do I direct it to connect through one of the other three? Thank you, Gwen Belt
(4,017 Views)
I believe that the choice of ethernet interfaces is completely up to the operating system.   You just need to have things
configured in the PC so that the IP address of each server is in a subnet assigned to the proper interface.
Jim
(4,011 Views)
Hi Gwen,
If you're using CVI 7.1 or later, you can use the ConnectToTCPServerEx function, which allows you specify the client port number as a parameter to the function.
Luis
(3,956 Views)
