LabWindows/CVI
Labwindow/CVI over Labview
Can anyone give me the pros and cons of using Labwindow/CVI over Labview?
raj
(3,990 Views)
If there are not any theoretical limits (like a lack of support of LV or CVI) for your application, this is a very subjective decision.
It is also a sensitive issue 😉 since people kinda commit to one of them and believe it is better than the other, sometimes in a fanatic manner.
There many forum threads about that in various discussion boards.
I did a title search and found this, this, this, this and this.
It will give you some idea, and you can then search further.
Message Edited by ebalci on 28-12-2009 11:51 AM
S. Eren BALCI
IMESTEK
(3,987 Views)
Hi Raj,
in my opinion you there isn't a way to "calculate" or "demonstrate" which language is better or worse. As ebalcy already pointed out your feeling, habits and experience can orient you towards one or the other. A significative part of this decision can derive from available resource you can count on: technical suppoert from experienced users, friends or collegues with which to discuss some problem or solution and so on.
Just to add some additional point of view, I can point you to this, this and this thread which can give you some more elements on which to base your decision.
Message Edited by Roberto Bozzolo on 12-28-2009 12:37 PM
(3,971 Views)
