LabWindows/CVI
mySQL and SQL Toolkit 2.0
I'm using a mySQL database and the sql toolkit  2.0 in a CVI Labwindows application.
I have a problem when the database increases in size. Indeed, when the number of records reaches 3 millions, the program memory is 1.7 Go. So, it stops on a Out of Memory error.
The program memory increases when I use the function DBActivateMap, before adding records.
For the moment, I'm using the following method for adding records :
  DBBeginMap
DBMapColumnToDouble
DBMapColumnToDouble
DBActivateMap
DBCreateRecord
  DBPutRecord
Is there an other possibility to open the table and add records ?
Thank you for your help.
Benjamin
(5,328 Views)
Hi Benjamin,
I do not think that this is a question of suitable commands but rather of a 32 bit operating system, where maximum memory is 2 GB.
(5,317 Views)
Thank you for your answer.
I think too that with a 64bit os, the number max of records will increase.
But for the moment, it isn't possible to change for this OS.
I think it's strange that  for adding one record to a 3 million record table, the memory available must be upper than 2GB !
That's why I think it is possible I don't use the best commands.
(5,310 Views)
Accepted by Benjamin.J
Did you try to use directly sql statement in order to insert a data, for that you can use this function:
DBActivateSQL
And for the sql statement you can use that :
INSERT [INTO] table [(colums)]
{VALUES (list_of_value) | requête_select | DEFAULT VALUES }
Nacer M. | Certified LabVIEW Architecte
(5,243 Views)
Hello.
I don't use DBActivateSQL, but DBImmediateSQL, with a SQL Statement, and it's working very well. Now, it is not necessary to load the database, so it is faster. Thank you very much.
Benjamin
(5,147 Views)
