LabWindows/CVI
new message
            Hello, I'm trying to draw an x-array and a y-array using ploXY function; but an inclined line is composing on my graph. I'm using that code:
plot_handle = PlotXY (testler, TESTLER_GRAPH, inputNumber, amplitude, 1024, VAL_INTEGER, VAL_DOUBLE, VAL_THIN_LINE, VAL_EMPTY_SQUARE, VAL_DOT, 1, VAL_RED);
           In this code, inputNumber is an integer, amplitude is a double value. I'm drawing a point in the each 'for' loop using the plotXY in the above; but an inclined line that is between 0 and the last produced point, is also composing together with my correct points.
           How can I prevent this inclined line?
(6,288 Views)
I am not sure if I understand you correctly but you should provide data arrays, not individual points: PlotXY will plot all the data in the two arrays by itself, you do not need an extra loop. So inputNumber should be an array of integers: inputNumber [ 1024 ].
(6,285 Views)
         I want to draw my graph instantly. I take my data from e3631a dc power supply. I can draw the graph after obtaining my all data; but I want to draw my graph simultaneously while taking my data from e3631a. During drawing this graph, I'm encountering unexpectedly with an inclined line from 0 to the value that is read in current.
        What can I do to avoid this unexpected line?
        The following is a part of my code:
double sonuc;
int plot_handle;
int CVICALLBACK CBBasla (int panel, int control, int event,
       void *callbackData, int eventData1, int eventData2)
 FILE *fp;
 switch (event)
  case EVENT_COMMIT:
   int i;
   fp=fopen(fileName,"a");
   fprintf(fp,"\n\n Input Number     Amplitude      Upper Level     Lower Level   Status\n\n");
   for(i=0;i<1024;i++)
    hpe363xa_queryOutputCurr3631 (vi, 1, &sonuc);
    lowerlevel[i]=-3;
    upperlevel[i]=3;
    amplitude[i] = sonuc;
    if (amplitude[i] > upperlevel[i] || amplitude[i] < lowerlevel[i])
     status[i]='F';
    else
        status[i]='P';
    fprintf(fp,"   %d        %9.5f       %9.5f       %9.5f        %c\n",inputNumber[i], amplitude[i], upperlevel[i], lowerlevel[i], status[i]);
    inputNumber[i]=i+1;
    plot_handle = PlotXY (testler, TESTLER_GRAPH, inputNumber, amplitude, 1024, VAL_INTEGER, VAL_DOUBLE, VAL_SCATTER, VAL_EMPTY_SQUARE, VAL_DOT, 1, VAL_RED);
   fclose(fp);
   break;
  case EVENT_RIGHT_CLICK:
   break;
 return 0;
(6,278 Views)
If you really want to update your graph so many times (note that it might slow down your data acquisition) you only should plot the data you have acquired, i.e., use something like
plot_handle = PlotXY (testler, TESTLER_GRAPH, inputNumber, amplitude, i+1, VAL_INTEGER, VAL_DOUBLE, VAL_SCATTER, VAL_EMPTY_SQUARE, VAL_DOT, 1, VAL_RED);
Right now you are plotting all 1024 data points, even if you have measured only 5 - the other data values probably are zero, and because you are plotting all of them, you see a line to ( 0, 0 ).
(6,274 Views)
Hi Eren.
is your problem solved?
If no, what's missing?
If yes, good Smiley Happy Then please mark the appropriate answer as solution.
(6,257 Views)
There is always the good old way, maybe not brilliant but working Smiley Wink
oldX = 0.0; oldY = 0.0;
while (condition) {
	// Acquire new measures
	// Values stored in X, Y variables
	PlotLine (..., ..., oldX, oldY, X, Y, ...);
	// Save last values acquired
	oldX = X; oldY = Y;
(6,247 Views)
         Hi Wolfgang,
         I solved my problem with your solution. Thank you vey much.
         Regards.
(6,238 Views)
