LabWindows/CVI
nican ncWriteMult returns "0xBFF6200A A known feature is not supported"
I'm trying to use ncWriteMulti function in CVi LabWindows with a VXI card  NI PXI-8464 and with the nican driver version 2.3
but whatever are the arguments I use to call the function, the driver allways returns me the following message
 "NICAN : (Hex 0xBFF6200A) A known feature is not supported. Solutions: refer to the descriptions in the manual to determine whitch feature is unsupported."
I tried different baud rates from 125k to 500k, different frame array size for 1 to 1000 but the message is allways the same
Have you ever experienced this ?
thank you for your help
Here is an extract of the code I use:
            AttrIdList[0] =         NC_ATTR_BAUD_RATE;
            AttrValueList[0] =      baudRate;
            AttrIdList[1] =         NC_ATTR_START_ON_OPEN;
            AttrValueList[1] =      NC_TRUE;
            AttrIdList[2] =         NC_ATTR_READ_Q_LEN;
            AttrValueList[2] =      0;
            AttrIdList[3] =         NC_ATTR_WRITE_Q_LEN;
            AttrValueList[3] =      0;
            AttrIdList[4] =         NC_ATTR_LOG_COMM_ERRS;
            AttrValueList[4] =      NC_TRUE;
            AttrIdList[5] =         NC_ATTR_CAN_COMP_STD;
            AttrValueList[5] =      0;
            AttrIdList[6] =         NC_ATTR_CAN_MASK_STD;
            AttrValueList[6] =      NC_CAN_MASK_STD_DONTCARE;
            AttrIdList[7] =         NC_ATTR_CAN_COMP_XTD;
            AttrValueList[7] =      0;
            AttrIdList[8] =         NC_ATTR_CAN_MASK_XTD;
            AttrValueList[8] =      NC_CAN_MASK_XTD_DONTCARE;
            status = ncConfig(Interface, 9, AttrIdList, AttrValueList);
            if (status < 0)
                PrintStat(status, "ncConfig TX");
                StopTxCallback (panelHandle, PANEL_STOP_TX, EVENT_COMMIT, 0, 0, 0);
            /* open the CAN Network Interface Object */
            status = ncOpenObject(Interface, &NetIntfObjhTx);
            if (status < 0)
                PrintStat(status, "ncOpenObject TX");
            NCTYPE_CAN_STRUCT* pFramesTab;
            pFramesTab = (NCTYPE_CAN_STRUCT*)calloc(nbFrames, sizeof(NCTYPE_CAN_STRUCT));
            for(index = 0; index < nbFrames; index++)
                pFramesTab[index].FrameType     = NC_FRMTYPE_DATA;
                pFramesTab[index].ArbitrationId = index;
                pFramesTab[index].DataLength     = 7;
                pFramesTab[index].Data[0] = 1;
                pFramesTab[index].Data[1] = 2;
                pFramesTab[index].Data[2] = 3;
                pFramesTab[index].Data[3] = 4;
                pFramesTab[index].Data[4] = 5;
                pFramesTab[index].Data[5] = 6;
                pFramesTab[index].Data[6] = 7;
            status= ncWriteMult(NetIntfObjhTx, nbFrames, pFramesTab);
            PrintStat(status, "ncWriteMult");
            free(pFramesTab);
Message 1 of 1
(3,434 Views)
