LabWindows/CVI
not able to run a customer writen program in Labview
I am using a NI AT-MIO-16E-10 board in conjunction with a custom writeen labview data acquisition program. It has bee running great until the computer was out of order recently. When I try to reinstall the custom writeent labview data acquisiton program, it shows a message as "please find the file 'shrink to XII 16 bit'". I don't know if it's a file from labview or the custom writeen program, and how to solve the problem.
(2,794 Views)
Since you don't know what got trashed when your PC was repaired, I suggest you 'un-install' labview, (maybe even de-fragment the disk to improve performance) then install labview again. This should give you a clean copy. Then re-install your board drivers & see if the code will then work. If not, contact the guy that wrote the programme!
(2,794 Views)
