LabWindows/CVI
outp() doesn't work in CVI for LVRT
I am trying to write a simple, no frills driver (as a DLL to be used in LVRT) for a generic Analog I/O board (PC/104 based, so it's an ISA bus). But when I select "LabView RT" or "Instrument Driver" as a target for my DLL, functions like outp() and outpw() produce link errors. Is there a simple and quick way to access I/O ports in this environment?
Thank you.
(3,737 Views)
No, the low level driver support is not available under LV RT. CVI accomplishes this functionality by providing a generic driver for Windows to do these kernel level functions. This driver can't be used on the RT OS. I don't know of any way to do this under LV RT. You definately don't have a way to do it from CVI, but there may be a way in LabVIEW RT. You might want to post this question to the LV RT forum to see if there is a way from LabVIEW.
Best Regards,
Chris Matthews
(3,737 Views)
Thanks, Chris!
On the same note, is there a way to use functions like viPoke() and viOut() without going through full blown VISA development process?
Thanks.
(3,737 Views)
I'm not sure what you mean by the full blown VISA development process. To use viPoke() and viOut() you would have to have a valid VISA session to your resource which would mean a few more function calls to configure and close the connection. I haven't used VISA for low level communication though, so I'm not sure exactly what it would involve.
Chris
(3,737 Views)
