LabWindows/CVI
pci das 4020
Hi everybody,
I'm actually working on labview, programming an acquistion card "DAS 4020/12 trigger". It's an acquisition card with 4 channel+1 trigger
All works good onely my trigger which want to absolutle trig on the chanel n°0. (so i have 3aquisition chanel +1acquistion&trigger instead of 4 acquistion +1trgger)
To prgram it, i use labview+universal library...
I give you thanks for all help you could give me
awawa
(3,736 Views)
I think you post in the wrong place.Here it's about LabWindows/CVI and you said you use LabVIEW, you maybe post your problem in the good place:  LabVIEW forum
(3,692 Views)
