print panel to file
i just want to print a panel, or actually a graph box within a panel, to an image file.   as a .jpg, .gif,.bmp, or whatever
 PrintPanel() doesnt work for me, it only prints a printer file.
any suggestions?  thanks
(4,292 Views)
Hi.
You can capture the current appearance of a control using GetCtrlDisplayBitmap(), then save it to a file using either SaveBitmapToJPEGFile() or
SaveBitmapToBMPFile(). Remember to call DiscardBitmap() when you are done.
All of these functions are in the User Interface library.
Colin.
(4,282 Views)
hey, thanks a lot.  that was exactly what i was looking for.
(4,195 Views)
How can I realize this when using CVI IDE 5.0, since there is not method "SaveBitmapToBMPFile" or "SaveBitmapToJPEGFile", as in the higher version?
Thanks very much!
    LI Xiaogai
(4,119 Views)
Hi LXGPanda,
Please try the solution offered by Roberto in Saving panel to file (jpeg format).
Cheers,
David Goldberg
Software R&D
(4,101 Views)
Hi AEDavid,
Thanks very much! I have tried as you suggested me, it indeed work!
Thanks again!
Best regards!
 LI Xiaogai
(4,089 Views)
