problem with variable view
I am debugging a piece of code in CVI2017; the code is a short function with local and global variables. I have a breakpoint in this function and once the debugger stops at the breakpoint I want to inspect some variable values.
View Variable View works as expected if the cursor is positioned over a local variable: the Variable and Call Stack window opens and the line with the selected variable is highlighted.
For some reason this does not work when I want to see the variable value that is defined in the same project but in a different file, i.e. as external.
Any suggestions what I should do to see all my variable values?
Thanks in advance!
Message 1 of 9
(5,079 Views)
To elaborate a bit more, the sample code looks like that:
void TestFunction ( void )
int test = 0;
test = extern_test;
return;
Now, right clicking and selecting 'View Variable Value' on the local variable test works (i.e., brings up the Variables window and highlights the variable), right-clicking on the externally defined variable extern_test does not bring up the Variables window. This seems to contradict the description in the manual Smiley Wink
Message 2 of 9
(5,054 Views)
With the simple project I attach it works for me. Is your use case different?
Message 3 of 9
(5,047 Views)
Hi Constantin,
with your project everything works as expected...
Thanks for your interest, now I will have to search for the differences...
Message 4 of 9
(5,044 Views)
Actually it may also happen to global variables that are not external, hm... Smiley Indifferent : right clicking and selecting 'View Variable Value' does not bring up the Variables window. So far I have not found the reason why sometimes Variable view works and sometimes not (it is not an especially memory hungry project)
Message 5 of 9
(5,007 Views)
In the mean time the issue has been reproduced by NI, they have assigned CAR #703092
Message 6 of 9
(4,941 Views)
Accepted by topic author Wolfgang
...and it has been fixed in CVI 2019 Smiley Happy
Thanks!
Message 7 of 9
(4,536 Views)
How do I see the details of the CAR and solution?
Message 8 of 9
(3,949 Views)
For every release of CVI there is a list of bug fixes / resolved issues, for 2019 this list is https://www.ni.com/de-de/support/documentation/bugs/19/-labwindows--cvi---2019-bug-fixes.html
Although in this specific case no more details are given, the bug is gone and I am happy 😁
Message 9 of 9
(3,942 Views)
