LabWindows/CVI
pulse signal in cvi whith NI6221
How do generate a pulse signal which variable frequency whith cvi fonction or NI DAQ.
I use NI 6221 DAQ.
Thanks.
PS: i whant control a motor stepper.
(4,786 Views)
You will find an example attached to this thread to generate a PWM with NI-DAQmx.
(4,746 Views)
Hello Benjamin,
Thanks for your PWM solution.
BcGam
(4,737 Views)
How do generate a pwm signal which variable frequency whith cvi function or NI DAQ.
I use NI 6259 DAQ.
We are able to generate PWM signal on counter output pin..
But our application required 20 pwm signal at one time. So we are trying to generate same on DIO pins.
We are able to generate pwm signal in Analog.
But we are facing problem in converting signal from analog to digital .
Thanks.
(4,154 Views)
