"Reverse" bytes in string
I have a string like this : "ABCDEF"
I want to get this from this string : "EFCDAB".
What's the best way to do that in CVI ?
Thanks in advance,
Blue
Message 1 of 15
(3,769 Views)
You are reversing 16bit words, not bytes here.
Message 2 of 15
(3,757 Views)
Something along this line? (str1 and str2 must be previously allocated in the correct size)
for (i = 0; i < strlen (str1); i++) {
	str2[i] = str1[strlen (str1) - i - 1];
Message 3 of 15
(3,746 Views)
This is more a C question than a CVI question... You can do this in place without need for an extra allocation by using an intermediate short. Something like (untested, caveat if string len is odd, caveat if UTF, etc)
char Str[]="ABCDEF";
int L=strlen(Str);
short C, *SC=(short*)Str;
for (int i=0; i<L/4; i++) {
 C=SC[i];
 SC[i]=SC[L/2-i];
 SC[L/2-i]=C;
Message 4 of 15
(3,742 Views)
Roberto, this will gave me "FEDCBA" and not "EFCDAB".
Message 5 of 15
(3,738 Views)
Hello gdargaud,
I will try this, thank you.
Message 6 of 15
(3,737 Views)
Correct, I didn't focused on expected target string and the quotes around "reverse"
Message 7 of 15
(3,733 Views)
gdargaud,
The code I tested, it's not good too.
Roberto, Yes, do you have a suggestion please ?
Message 8 of 15
(3,723 Views)
This should work for any string with any number of couples of chars.
The lack of explanations and comments is not casual. ðŸ¤£
    char *s = "ABCDEF";
    int len = (int)strlen(s);
    int len2 = (len / 4) * 2; // ;-)
    char c1, c2;
    for (int i=0; i<len2; i+=2) {
        c1 = s[i];
        c2 = s[i+1];
        s[i]   = s[len-2-i];
        s[i+1] = s[len-1-i];
        s[len-2-i] = c1;
        s[len-1-i] = c2;
Carlo A.
Megaris srl
Italy
Message 9 of 15
(3,712 Views)
You can also make use of SwapBlock function in the Programmer's Toolbox:
#include "toolbox.h"
#include <ansi_c.h>
static int		i, len, duplets;
static char	str[64];
strcpy (str, "ABCDEFGHIJKLMNOPQRSTUVWXYZ");
len = strlen (str);
duplets = len / 2;
for (i = 0; i < duplets; i += 2) {
	SwapBlock (str + i, str + len - i - 2, 2);
Just my 2c... after my initial gaffe ðŸ˜‰
Message 10 of 15
(3,706 Views)
