LabWindows/CVI
real time target PC hang
I am trying to setup a desktop PC as an RT for Labview 8.6.1. I have created the USB boot drive and formatted the hdd as FAT32. The USB boot drive was created with Labview Utility version 8.6. The USB installed the Labview RT Boot Loader and the RT Target PC detected the NIC. However when booting up, the computer just hang after that and I couldnt do anything else like change IP Address or install the RT OS.
The RT PC is a Dell Precision T3400 with Intel Pro 1000GT NIC. The host PC's firewall has been disabled, both it and the RT Target is connected to a Belkin router. Also I dont know if I need to use a switch or hub for the host PC to detect the RT Target?. I have attached a screenshot here. Any help is greatly appreaciated.
Thank you,
Max
Message Edited by MaxXx on 06-11-2009 07:20 PM
Message Edited by MaxXx on 06-11-2009 07:23 PM
(3,176 Views)
Accepted by topic author MaxXx
I have solved the problem. It was because of the Flash card reader. I unplugged it and the machine can now be detected in MAX.
Max
(3,165 Views)
