LabWindows/CVI
reportgen : NIReport_Print( ) hangs
using reportgen.fp, I've noticed that the print function didn't work with "shared printer" like "\\SrvProd\\HP Business 2230/2280". The NIReport_Print() function returns -4. It works fine with other printers.
Any suggestions ?
(3,166 Views)
Hello
Try running one of the nireports examples. I tried a shared printer and it seemed to work ok.
NIReport_Print (reportHandle, "\\\\tempest\\ae04", 1);
You might want to check if your slashes are correct. You should try using "\\\\SrvProd\\HP Business 2230/2280" instead. I got the same error number when I had the incorrect number of slashes
I hope this helps
Bilal Durrani
NI
Bilal Durrani
NI
(3,166 Views)
it was a good idea...I think it was the solution but it didn't work !. with the debug,I've changed the name of the printer, but unsuccessfully.
So, I continue to search.
Thank's
(3,166 Views)
