resizing the main panel - is it possible?
I want the main panel of my application to resize automatically at start up depending on which hardware is connected.
Am I correct in believing the correct command for this is SetCtrlAttribute ?  I'm having trouble trying to find which panel handle to pass though.  The main panel has the default handle 'panelHandle' and the controlID PANEL.  I've tried passing panelHandle and 0 as the arguments for the panel handle but in both cases I get non fatal runtime errors on execution.  I have not edited the uir header file at all.
Thanks for any help.
Gareth
(3,577 Views)
Accepted by gv1971
You need to use the SetPanelAttribute() function.
JR
(3,568 Views)
Fantastic!  Thanks!  I'd convinced myself that it must have been the setctrlattribute function and I was using it wrong.  Didn't realise there were functions just for controling the panel alone.
(3,557 Views)
Or SetPanelSize() and SetPanelPos()
Guillaume Dargaud
http://www.gdargaud.net/
(3,536 Views)
