LabWindows/CVI
rs485 manchester encoding
I currently have a PCI RS485 I/4 card.  Can i use it to do manchester encoding using CVI?  If so, how?
Else,
Is there any hardware that does manchester?
Gary Z.
(4,772 Views)
Hi Gary,
I am not really familiar with Manchester encoding, but what kind of speed will you need. The PCI 485/4 only goes up to 460kb/s, so you might consider a  High speed Digital I/O  board if you need something faster. Thanks.
Ebele O.
(4,738 Views)
Boards built around the 16550 UART are not going to support manchester encoding.  There are cards from other vendors that will.  I know cards built around the Hitachi HD64572 would support manchester.  They will not be as easy to use as the NI cards from CVI, but it can be done.
(4,706 Views)
