LabWindows/CVI
russian font on LabWindows CVI
hi,
i have a software in french langage and i'd like to pass it in russian. I downloaded cyrillic and i can write cyrillic in uir but i can't copy cyrillic from text file and paste it in uir. And i can't write cyrillic in the labwindows editor where i'd like to write cyrillic for the MessagePopup. I can put cyrillic by MessageBoxFont in registry but it's just code converter, it means nothing in russian langage.
how can i do?
(3,682 Views)
I suggest you to take a look at the following knowledge base : http://digital.ni.com/public.nsf/websearch/F23D7180B0A1A76B86256BC3004FD865?OpenDocument.
Benjamin CHARLES
Application Engineer
National Instruments France
(3,682 Views)
it was not this problem, my problem was to copy russian text from word to labwindows and i have found the solution : it was about word which is unicode and labwindows which is not, so i had to found a soft which can convert unicode to none-unicode and it works.
(3,682 Views)
