Greetings,
There might be another workaround, though you have to do a manual edit of your project file.  Try the following:
1. In LabWindows/CVI, exit out of the project in question.
2. In a text editor (like Windows notepad), open up the .PRJ file for your project.
3. In this file, find a key named "Distribution Kit GUID".
4. On this key, delete all of the text on the line after the "=" sign.
5. Reopen your project in CVI, and rebuild your distribution kit.  Windows will now think that your installer is "new".
Be aware that this workaround, as well as the one mentioned by tech supoort - has the side effect that the old project still stays installed, so you will have two entries in your Windows Add/Remove control panel.  Running uninstall on either entry from A
dd/Remove will uninstall all of the files.
Best Regards,
- WesW / NI
