I have some lengthy LabWindows/CVI software that controls various bits of hardware but I am having difficulty with an array from a VNA. There are 3 data transfer modes, I was using the ASCII mode but want to speed things up and go to Single Precision or 32 bit binary data transfer. The binary array is attached as a text file. The array starts with a #3452, then the Single precision data. the 3 after the # signals that there are 3 more digits to follow and then these 3 digits flag how many bytes are in the array (not counting 0A at the end). I cannot get the scan line correct to strip off the #3452, and then read the floating point numbers in correctly. I have looked at the help and while I know I am on the right track, just don't get it right. Any help would be greatly appreciated.
Scan(BufferRd, "%s>#%i[w5]%f[b4]", dummy, BufferB) is one attempt.
When I was using the ascii I used
Scan(BufferRd, "%s>#%i[w5]%s", dummy, BufferB) which worked fine.
