06-17-2016 12:52 PM
Hello -,
I am trying to develop a data acquistion/collection using CVI/LabWindows 8.1.
I added all the required include and lib files.
But I get error in linking.
The link errors is about "security_cookie", and "security_check_cookie".
I tried to disable it using the compiler flag "/GS-", but didn't work.
I need your help please.
I attached a png file with the errors.
Thank you for responding me promptly.
Farideh
Solved! Go to Solution.
06-17-2016 02:53 PM
Hello Farideh,
Try including in the project niDCPower.fp rather than nidcpower.lib. According to this it is located in <IVIROOTDIR32>\Drivers\niDCPower\niDCPower.fp
Also this article suggest inlcuding bufferoverflowU.lib. See if you have this lib.
Constantin
06-17-2016 04:08 PM
Hi Constantin,
Once I added the instrument file "nidcpower.fp", the CVI 8.1 complained that it cannot read the format of the function panel with an older version of CVI.
The NIDCPower driver I installed is 15.5 version.
What version of NIDCPower should I install with CVI 8.1?.
Thanks.
As well the bufferoverflowU.lib was found and did not resolve the issue with Security_cookie.
Thanks again.
Farideh
06-18-2016
08:55 AM
- last edited on
09-15-2026
05:53 PM
by
Content Cleaner
Hello Farideh,
Indead, in the readme it says NI-DCPower 15.1 supports LabWindows™/CVI™ 2012 or later. It seems that version 1.4 is the last one that suports CVI 8.1. Version 1.5 supports LabWindows™/CVI™ 8.1.1 or later. If you have CVI 8.1.1 you can use NI-DCPower 1.6
Constantin
06-27-2016 12:50 PM
Hello ,
Thank you for assisting me in resolving the issue. It is being resolved.
Thank you again. Kudos.
Farideh
