08-11-2004 03:10 PM
08-12-2004
10:06 AM
- last edited on
08-11-2026
03:31 PM
by
Content Cleaner
Hi Derek,
You have an option on that last section to use either "socket" or "instr". The difference is instr specifies that you are connecting to something using the TCP/IP instrument protocol, while socket just exposes the raw network socket connection. You, as a programmer, do not have to specify the socket number. All you should have to do is specify if this is a socket connection or a instr connection.
Here's a link to a helpful knowledgebase:
Link
Hope this helps!
Jeremy L.
08-13-2004 10:31 AM
08-16-2004 12:25 PM
