source code printing does not observe color settings
when printing part of my source code I was surprised to see integers printed in orange - although my Environment Color Settings have black for all numbers (and syntax coloring enabled). Could it be that the printer uses the default color settings and not the actual user settings?
(2,912 Views)
Accepted by Wolfgang
It's documented 🙂
The Print command prints the window contents to a printer or a file. If you print to a color printer, the source code is printed using the default syntax colors.
(2,866 Views)
OK, you win Smiley Happy ...and I should have read the help...
(2,860 Views)
