LabWindows/CVI
square command button
i want to write a code which consists of many text messages and two command buttons named "Next Instruction" and "Previous Instruction". Text messages are already written and will hide when program will start. when i press next instruction button the second instruction will appear and first one will hide, when i press the button second time third instruction will come and second will hide. when i press previous instruction button it will go backwards. Kindly help me in writing this code. I am stuck here.
(5,915 Views)
why not start
  • working through the Getting Started Manual
  • and then exploring some of the examples provided with CVI? You can use the example finder (Help / Find examples) and search for 'Building User Interfaces'
For some more specific questions / problems people here on the forum will help you further
(5,898 Views)
#include <cvirte.h>
#include <userint.h>
#include "instructions.h"
static int panelHandle;
// Panel Initialization//////////////////////////////////////////////////
int main (int argc, char *argv[])
if (InitCVIRTE (0, argv, 0) == 0)
return -1; /* out of memory */
if ((panelHandle = LoadPanel (0, "instructions.uir", PANEL)) < 0)
return -1;
SetCtrlAttribute (panelHandle, PANEL_INSTRUCTION_2, ATTR_VISIBLE, 0);//Instruction 2 not visible
SetCtrlAttribute (panelHandle, PANEL_INSTRUCTION_3, ATTR_VISIBLE, 0);//Instruction 3 not visible
SetCtrlAttribute (panelHandle, PANEL_INSTRUCTION_4, ATTR_VISIBLE, 0);//Instruction 4 not visible
DisplayPanel (panelHandle);
RunUserInterface ();
DiscardPanel (panelHandle);
return 0;
// Next_Instruction Callback Function/////////////////////////////////////
int CVICALLBACK Next_Instruction (int panel, int control, int event,
void *callbackData, int eventData1, int eventData2)
switch (event)
case EVENT_COMMIT:
SetCtrlAttribute (panelHandle, PANEL_INSTRUCTION_2, ATTR_VISIBLE, 1);//Instruction 2 visible
SetCtrlAttribute (panelHandle, PANEL_INSTRUCTION_1, ATTR_VISIBLE, 0);//Instruction 1 not visible
break;
case EVENT_RIGHT_CLICK:
break;
return 0;
// Previous_Instruction Callback Function/////////////////////////////////
int CVICALLBACK Previous_Instruction (int panel, int control, int event,
switch (event)
case EVENT_COMMIT:
SetCtrlAttribute (panelHandle, PANEL_INSTRUCTION_1, ATTR_VISIBLE, 1);//Instruction 1 visible
break;
break;
return 0;
// Quit Callback Function////////////////////////////////////////////////
int CVICALLBACK QuitCallback (int panel, int control, int event,
switch (event)
case EVENT_COMMIT:
QuitUserInterface (0);
break;
break;
return 0;
I wrote the code but i dont know how to execute third instruction when user click the next instruction button second time. Plz help me out
(5,895 Views)
Accepted by topic author Kazuya_Mishima
So it looks like you have to handle 3 situations and display message 1-2-3 depending on the case you are.
You could put a hidden numeric on the panel and in button callbacks read the numeric, increment/decrement as required and then display the appropriate message depending on counter value, hiding the others.
(5,893 Views)
Thanks a lot Roberto. Your suggestion will be more helpful for me.
(5,882 Views)
