LabWindows/CVI
ssize_t being redefined in cvidef.h
I'm in the process of porting an existing program from Windows 10 to Linux (RHEL 6.9) that uses LabWindows/CVI and have an issue on the Linux side where I'm getting an error stating that ssize_t is being redefined in cvidef.h.  I'm using the CVI RTE 2013 for Linux and am not sure how to get around this problem as ssize_t is defined in /usr/include/sys/types.h in G++.
Is this a known issue and if so, how do I get around it?  If it's not, are there any ideas on how to get around this?
(3,493 Views)
Where else is ssize_t being defined? This was new to me, so I had to look it up:
"Additionally, POSIX includes ssize_t, which is a signed integral type of the same width as size_t. "
(3,432 Views)
It is defined in /usr/include/sys/types.h and /usr/local/natinst/cvi2013/include/cvidef.h.
(3,424 Views)
Accepted by DesertBroncoFan
The CVI code has #ifdefs around it that control whether or not this is defined:
#if !defined(_SSIZE_T_DEFINED) && !defined(__ssize_t_defined)
#define _SSIZE_T_DEFINED
#ifdef _NI_mswin64_
typedef __int64             ssize_t;
#else
typedef int                 ssize_t;
#endif
#endif
You may be able to simply define that before you #include, that way the CVI code will not include its own definition (assuming the one in types.h is correct for your use). Just stick this before you start including files:
#include <…..files after this....>
I am looking at a Windows system, so there may be a similar ifdef in your types.h, so you could go the other way, if so.
(3,406 Views)
Thanks, I didn't see that before.
I'll give that a try and see what happens.
(3,395 Views)
