steps to integrate 32-bit dll written in VC++ in LabWindows
List out the steps required to integrate the dll written in VC++ in LabWindows
(3,576 Views)
1. Copy the .dll, .lib, and .h file from VC++ to your LabWindows project directory.
2. Add the .lib file to your CVI project list.
3. #include the VC++ .h file in any CVI .c file that will call a function in the VC++ DLL.
4. You're ready to use CVI to call functions from the VC++ DLL.
Since CVI is ANSI C and not C++, there are some restrictions on the VC end. All the exported functions need to be be extern'ed as C functions. For example, in the VC .h file, look for these blocks surrounding the function prototypes.
#ifdef __cplusplus
extern "C" {
#endif
// prototypes of functions exported for CVI to call
#ifdef __cplusplus
#endif
(3,576 Views)
There's more info in the discussion here.
(3,576 Views)
Can we be more specific?
I am trying to call a VC++ DLL. I'm not quite sure how to moify the .h file containing the function prototypes.
A snippet from the original  .h file"
// Open grabber. int __stdcall Open(HANDLE &InterfaceHandle, int SourceIndex, int Width, int Height, int Rate);
 I changed it to:
// Open grabber. __declspec(dllexport) int __stdcall Open(HANDLE *InterfaceHandle, int SourceIndex, int Width, int Height, int Rate);
I can compile, but I get an "Undefined Symbol" error while linking. I've moved the lib file to the project folder with no change in results.
(3,017 Views)
