Hello bstroup,
I've confirmed that there is in fact a limitation of 500 items in slide controls, which is not documented. And it's also true that CVI isn't handling excessive items very well.
I'd be happy to remove the limitation for the next version of CVI, but like James pointed out, when the limitation isn't there, and you add 4000 items you end up with a basically a solid bar (unless the knob is large enough to span several monitors). And it's also quite slow.
Luis
