 petrz
			petrz
			12-12-2013 01:39 AM
I'm creating IVI driver and I want to show relay information in NISE Virtual Device Relay Information table. Is it possible do that or is this options avilable only for NI switch?
Solved! Go to Solution.
 BalazsNagy
			BalazsNagy
		12-13-2013
		04:08 AM
 - last edited on
		11-15-2024
		09:19 AM
 by
		 Content Cleaner
			Content Cleaner
Dear petrz!
First of all let me wellcome You on NI Discussion Forums!
Please allow me to recommend some learning material for NISE:
Learn to Program Switch Systems Using NI Switch Executive
Pleae let me know, if Your problem is solved.
Best Regards,
12-13-2013 04:22 AM
For NI drivers it works fine. But I want use it in my own IVI driver, which I wrote in CVI.
 BalazsNagy
			BalazsNagy
		12-16-2013
		06:08 AM
 - last edited on
		11-15-2024
		09:23 AM
 by
		 Content Cleaner
			Content Cleaner
Dear petrz!
Sorry for my late reply!
Did You implement he relay count functionality in Your own dirver?
I searched some useful documents, hat may help:
Instrument Driver Development Tools and Resources
The mos useful is the LabWindows CVI Instrument Driver Developers Guide (probably You know it)
Getting Started with IVI Drivers
Of course http://www.ivifoundation.org is one of the mos timportant resources.
Related to the usage of third party switches, I found these:
You may try to implement Your driver by modifying the IVI driver for an NI SWITCH.
Creating or Modifying IVI Class Simulation Drivers
I hope these resources may help You.
Best Regards,
12-16-2013 07:25 AM
How the realy count functionality can be implemented? I can't find it in both IVI switch specification and driver atributes (im using CVI IVI switch driver template).
I'm can't found any information about relay status or count in given links.
 SachaE
			SachaE
			12-16-2013 08:32 AM
you're referring to the listing underneat the switch executive virtual device where it brings up the Relay Information table for each selected switch unit.
Most of the NI switches have an onboard EEPROM which manages the list of switches and their count of interactions . The IVI driver for the NI hardware is niswitch, and the function to get the count back is niSwitch_GetRelayCount.
Unfortunately, that's not an IVI-C standard call (more of an extension), so unless you try making that inside your DLL (following the IVI standard of the prefic name) then it's going to be limited to the way in which the NI hardware and it's API works.
Sorry
Sacha
