LabWindows/CVI
table column label missing horizontal line
I have a table on a panel.  Prior to CVI 2019, the label row or header row included a horizontal line underneath.  This gave nice visual separation between it and the data below.
Now in CVI 2019 I've notice this is missing. And I can't seem to find an attribute that might turn this on.
(2,378 Views)
Accepted by ElectroLund
I'm not sure whether the problem lies in the CVI environment or in the execution on Windows 10 instead: on my laptop CVI 2012, 2015 and 2017 are installed and the aspect of the table is consistent across all versions. I tend to say that this behavior either depends on the RTE (which as you know is the one of the latest IDE installed) or on the OS.
As far as I know you have two alternatives:
- Exclude the Use Windows Visual Style for Controls option in panel attributes, but this heavily changes the aspect of all controls
- Paint table cells background e.g. with a very light gray background (to do this you must disable Conform to System Colors option; you cannot paint row and column labels if you keep the Windows visual style active)
(2,351 Views)
