LabWindows/CVI
the device didn't respond to a *IDN? query
help help help!
Hello everyone, I'm a beginner of labwindows, and I connected my laptop with a Motion Controller through a GPIB, but the Measurement & Automation Explorer said " the device didn't respond to a *IDN? query, the PAD is 2, SAD is 0, so could you help me figure out what's wrong with my operation? Thank you so much.
(3,829 Views)
It simply means that particular instrument did not respond to the "IDN?" command.  Some instruments do not support that command, but it does no harm.  If you can communicate with the instrument I would not worry about it.
(3,815 Views)
Hello, mvr! thank you for your information, but I saw my boss he can get the answer asking "*IDN?", but he is in Brazil, so he couldn't help me. I'm using GPIP-USB-HS 488.2 2.73version for XP.  The instrument is a motion conctroller, doesn't look so old.
(3,812 Views)
Check the controlers manual for the commands it understands. As we don't know the controlers make and type, we can't do that for you. And you might also check if it needs some termination character for its commands.
(3,794 Views)
That secondary address of 0 made me a little suspicious.
Noone else pointed out, so it may be OK but it seemed like a special address to me.
Can you change the address settings and try again?
Are there other devices to your bus? Do they respond to IDN?
Maybe you can attach an instrument known to be working and try with it.
S. Eren BALCI
IMESTEK
(3,792 Views)
