timer control weirdness
Hi! bruno,
There are three functions in your dll: DestroiTemporizador(), CriarTemporizador(), and Temporiza().
Could you explain how one should use them instead of NI's Timer() or AsyncTimer()?
Thanks!
Message 11 of 14
(1,252 Views)
How it works is simple.
You must initialize the timer with CriarTemporizador(CreateTimer) in the start section with the time(in milliseconds) which you want wait.
In the code section who you want to be timed you will put Temporiza (Wait). This functon returns the time thats the system waits.
The precision of the timer depends of the precision of the processor counters and not of the real-time clock.
And finally you destroy the tmer with the function DestroiTemporizador (DestroyTimer).
Message 12 of 14
(1,222 Views)
Thanks!  I will give it a try....
Would be nicer if the function names are in English.
Message 13 of 14
(1,202 Views)
I dont speak english Smiley Tongue
Message 14 of 14
(1,200 Views)
