LabWindows/CVI
timer
I was wondering: I have a timer. Inside the timer callback I have a function that should be running once the timer is ON. but I notice that this function is beeing executed 5 times before exit. any explaination?
(3,994 Views)
Are you filtering events inside the callback? You should execute the code only for EVENT_TIMER_TICK event, otherwise the callback could be executed for other events like EVENT_DISCARD and so on.
(3,989 Views)
Here is what I have:
int CVICALLBACK timer3 (int panel, int control, int event,
  void *callbackData, int eventData1, int eventData2)
 switch (event)
  case EVENT_TIMER_TICK:
   enablingTest();
   break;
 return 0;
enablingTest() function is just a function executing without any delay or sleep inside.
Some variable in this functions will be used by other. Which seems to create a delay of about 4 sec as this function is executing about 4 times before exit.
also to mention, in my application I have 2 other timers but they running other functions independant to this.
(3,981 Views)
Which is the timer interval? And how long takes the function to execute?
Could you print some debug informations to help discriminating how it is working? Something like that:
 double tini;
 switch (event)
   tini = Timer ();
   enablingTest();
   DebugPrintf ("%s Inside the switch. Time taken: %.2f\n", TimeStr (), Timer () - tini);
   break;
 DebugPrintf (%s Out of the switch. Event %d\n" TimeStr (), event);
 return 0;
(3,977 Views)
