LabWindows/CVI
verilog
Just some curiosity:
Does anybody know some verilog coding.
I have some strings in my memory file. and I have a series of incoming strings so that each time I have a string coming in I will compare it with what is in my memory and found the match.
Any piece of codes?
Thank you.
(3,685 Views)
Hi wala,
I hope you are doing well today!  I do have some questions that I hope can clarify what you are working with.  First, what sort of hardware are you using?  Are you using verilog to program with an FPGA?  Also, are you using LabWindows/CVI to write your code?  Any other information that you could provide us regarding your project would be very benificial.  Thanks, wala!  Have a great day!
Taylor G.
Product Support Engineer
www.ni.com/support
(3,659 Views)
No, I am not using labwindows with this, I was just curious if someone could help. This is a FPGA project, can go with any asic..
(3,655 Views)
Hi wala,
Are you using any particular National Instruments FPGA hardware?  If you are looking for coding examples for verilog, I have attached a link to a Xilinx User Community Forum search that has quite a number of verilog topics.  If you have a particular question regarding National Instruments hardware, you will probably get better help if you post the question in its respective forum.  I hope this helps, wala!  Have a great day!
Xilinx User Community Forum: Verilog Search
Taylor G.
www.ni.com/support
(3,637 Views)
Thanks for this.
(3,619 Views)
