LabWindows/CVI
write OPC client with LabWindows/CVI
I'm working on a project that requires communicating with Unidrive through OPC Server. I'm programming with LabWindows/CVI.
I cannot make those function calls work that require SAFEARRAY parameter to be passed in. For example, IOPCGroupAsyncRead( )...
Want to know if anybody has done the same thing successfully. I need your help. Thanks.
Message 1 of 17
(6,368 Views)
Hi Marg SZ,
What version of  LabWindows/CVI are you using? Are you seeing any specific errors when trying to use the function calls?
Perry S.
Message 2 of 17
(6,348 Views)
Hi Perry,
I'm using LabWindows/CVI 6.0. There is no error messages. I can only read/write item successfully because they do not require SAFEARRAY parameters.
I would appreciate if you can help.
Margaret
Message 3 of 17
(6,343 Views)
Hi Margaret,
How are you creating the safe arrays? Is your array 1D or 2D? Are you using the conversion functions in LabWindows/CVI?
Perry S.
Message 4 of 17
(6,324 Views)
My code is as follows. Some of the variables are global. Thanks.
void GroupAsyncRead(void)
   OPCAutomationObj_OPCItems ppItems;
   OPCAutomationObj_OPCItem  ppItem;
   long numItems, hvalue, i;
   SAFEARRAY *serverHandles, *errors;  SAFEARRAYBOUND rgsabound[1];
   OPCAutomation_IOPCGroupGetOPCItems(OPCGroupHandle, &Error_Info, &ppItems);
   OPCAutomation_OPCItemsGetCount(ppItems, &Error_Info, &numItems);
   rgsabound[0].lLbound = 0;
   rgsabound[0].cElements = numItems;
   serverHandles = SafeArrayCreate(VT_I8, 1, rgsabound);
   for(i=0; i < numItems; i++)
      OPCAutomation_OPCItemsItem(ppItems, &Error_Info, CA_VariantInt(i+1), &ppItem);
      OPCAutomation_OPCItemGetServerHandle(ppItem, &Error_Info, &hvalue);
      SafeArrayPutElement(serverHandles, &i, &hvalue);
   OPCAutomation_IOPCGroupAsyncRead(OPCGroupHandle, &Error_Info, numItems, &serverHandles,
                                                  errors, GetTransactionID(), &cancelID);
   asyncReadInProgress = 1;
   OPCAutomation_DIOPCGroupEventRegOnAsyncReadComplete(OPCServerHandle, ProcessGroupAsyncReadComplete, NULL, 1, NULL);
   SafeArrayDestroy(serverHandles);
   SafeArrayDestroy(errors);
Message 5 of 17
(6,321 Views)
Sorry, I pasted it wrongly in the previous post. "errors" is passed by reference as follows.
                                                  &errors, GetTransactionID(), &cancelID);
Message 6 of 17
(6,318 Views)
Hi Margaret,
I think that you are using the wrong functions to create your safe arrays. Please use the functions that are located in the ActiveX Library, Array section.
Perry S.
Message 7 of 17
(6,311 Views)
Hi Margaret,
Where did you get the functions that you are using to create the safearrays? Which CVI library?
Perry S.
Message 8 of 17
(6,299 Views)
Perry,
Those are functions of Windows SDK. I haven't tried your suggestion on using ActiveX Array functions.
Thank you for following on this.
Margaret
Message 9 of 17
(6,297 Views)
Hi Margaret,
Let me know how it works when you try it.
Perry S.
Message 10 of 17
(6,287 Views)
