LabWindows/CVI
write OPC client with LabWindows/CVI
Sure, I will but it will be 10 days later since I'm going on a travel. Thanks.
Message 11 of 17
(1,566 Views)
Perry, I'm back from business trip. Just now I tried using ActiveX Array functions but it still won't work. My code is as follows. Any idea what's the problem? Thanks. Margaret int AsyncReadCompleteID=0; void GroupAsyncRead(void) { char *v_item; long *v_handle; OPCAutomationObj_OPCItems ppItems; OPCAutomationObj_OPCItem ppItem; long numItems, hvalue, i; SAFEARRAY *serverHandles, *errors; status = OPCAutomation_IOPCGroupGetOPCItems(OPCGroupHandle, &Error_Info, &ppItems); status = OPCAutomation_OPCItemsGetCount(ppItems, &Error_Info, &numItems); v_handle = (long *)malloc(sizeof(long)*numItems); for(i=0; i < numItems; i++) { status = OPCAutomation_OPCItemsItem(ppItems, &Error_Info, CA_VariantInt(i+1), &ppItem); // status = OPCAutomation_OPCItemGetItemID(ppItem, &Error_Info, &v_item); //verify status = OPCAutomation_OPCItemGetServerHandle(ppItem, &Error_Info, &hvalue); v_handle[i] = hvalue; } status = CA_Array1DToSafeArray(v_handle, CAVT_LONG, numItems, &serverHandles); //AsyncRead returns a negative value to status status = OPCAutomation_IOPCGroupAsyncRead(OPCGroupHandle, &Error_Info, numItems, &serverHandles, &errors, GetTransactionID(), &cancelID); status = OPCAutomation_DIOPCGroupEventRegOnAsyncReadComplete(OPCServerHandle, ProcessGroupAsyncReadComplete, NULL, 1, &AsyncReadCompleteID); // SafeArrayDestroy(serverHandles); // SafeArrayDestroy(errors); }
Message 12 of 17
(1,546 Views)
Perry, I just come back from a business trip. I tried the ActiveX Array functions and it still won't work. My code is as follows. Any idea what's the problem? Thanks, Margaret int AsyncReadCompleteID=0; void GroupAsyncRead(void) { char *v_item; long *v_handle; OPCAutomationObj_OPCItems ppItems; OPCAutomationObj_OPCItem ppItem; long numItems, hvalue, i; SAFEARRAY *serverHandles, *errors; status = OPCAutomation_IOPCGroupGetOPCItems(OPCGroupHandle, &Error_Info, &ppItems); status = OPCAutomation_OPCItemsGetCount(ppItems, &Error_Info, &numItems); v_handle = (long *)malloc(sizeof(long)*numItems); for(i=0; i < numItems; i++) { status = OPCAutomation_OPCItemsItem(ppItems, &Error_Info, CA_VariantInt(i+1), &ppItem); // status = OPCAutomation_OPCItemGetItemID(ppItem, &Error_Info, &v_item); //verify status = OPCAutomation_OPCItemGetServerHandle(ppItem, &Error_Info, &hvalue); v_handle[i] = hvalue; } status = CA_Array1DToSafeArray(v_handle, CAVT_LONG, numItems, &serverHandles); //AsyncRead returns a negative value to status. status = OPCAutomation_IOPCGroupAsyncRead(OPCGroupHandle, &Error_Info, numItems, &serverHandles, &errors, GetTransactionID(), &cancelID); asyncReadInProgress = 1; status = OPCAutomation_DIOPCGroupEventRegOnAsyncReadComplete(OPCServerHandle, ProcessGroupAsyncReadComplete, NULL, 1, &AsyncReadCompleteID); // SafeArrayDestroy(serverHandles); // SafeArrayDestroy(errors); }
Message 13 of 17
(1,545 Views)
The code was messed up. int AsyncReadCompleteID=0; void GroupAsyncRead(void) { char *v_item; long *v_handle; OPCAutomationObj_OPCItems ppItems; OPCAutomationObj_OPCItem ppItem; long numItems, hvalue, i; SAFEARRAY *serverHandles, *errors; status = OPCAutomation_IOPCGroupGetOPCItems(OPCGroupHandle, &Error_Info, &ppItems); status = OPCAutomation_OPCItemsGetCount(ppItems, &Error_Info, &numItems); v_handle = (long *)malloc(sizeof(long)*numItems); for(i=0; i < numItems; i++) { status = OPCAutomation_OPCItemsItem(ppItems, &Error_Info, CA_VariantInt(i+1), &ppItem); // status = OPCAutomation_OPCItemGetItemID(ppItem, &Error_Info, &v_item); //verify status = OPCAutomation_OPCItemGetServerHandle(ppItem, &Error_Info, &hvalue); v_handle[i] = hvalue; } status = CA_Array1DToSafeArray(v_handle, CAVT_LONG, numItems, &serverHandles); //AsyncRead returns a negative value to status. status = OPCAutomation_IOPCGroupAsyncRead(OPCGroupHandle, &Error_Info, numItems, &serverHandles, &errors, GetTransactionID(), &cancelID); status = OPCAutomation_DIOPCGroupEventRegOnAsyncReadComplete(OPCServerHandle, ProcessGroupAsyncReadComplete, NULL, 1, &AsyncReadCompleteID); // SafeArrayDestroy(serverHandles); // SafeArrayDestroy(errors); }
Message 14 of 17
(1,542 Views)
Hi Marg SZ,
Could you upload a Screen shot of your code? That would be alot clearer or me. Please help me understand what you meant by "it did not work"? Did you get an error? Please let me know.
Thanks.
Perry S.
Message 15 of 17
(1,537 Views)
Perry,
Please see the attached code.
Margaret
Message 16 of 17
(1,527 Views)
Hi Marg SZ,
Here is an online help file that describe how safearrays are used in CVI.
http://zone.ni.com/reference/en-XX/help/370051H-01/cvi/cvivariants_and_safe_arrays/
Here is the help file on how to create safe arrays in CVI.
http://zone.ni.com/reference/en-XX/help/370051T-01/cvi/libref/cvica_array1dtosafearray/
Please follow these to create your safearray. Have a great day.
Perry S.
Message 17 of 17
(1,518 Views)
