LabWindows/CVI
to save ctrl with confirmation dialog box
Hi all
i want to save ctrl but the problem is that when i call the savectrl function.it saves it but i dont know about its location etc.
actually i want when i call save ctrl function a confirmation dialog box is appeared and ask me for directory and type of file as in the case of other windows.
wait for some good reply. thanks
sia
(2,829 Views)
Hi, I suppose you are trying to use SaveCtrlBitmapToFile () function. This function accepts a pathname as an input, so you can set exactly where to save the image.
In case you want to give your customer a full navigate-and-select functionality you can add FileSelectPopup before saving the control. FileSelectPopup permits the user to navigate and select/write a filename. Provided that you choose "Save" as the button label, this function also checks for duplicates and emits the standard "File exist: cancel / overwrite" popup message. The pathname returned from this function can then be passed to SaveCtrlBitmapToFile function.
(2,824 Views)
