LabWindows/CVI
typrdef struct passing by reference
i need help with passing my typedef struct by reference instead by value, I never really did a pass by reference on a typedef struct  i use pass by reference on everything else
I cut some some stuff out like my error handling, so that i fit the right amount of characters in the message.
typedef struct
  int WidthCoordinate;
  int HeightCoordinate;
} FRAME_DETAILS;
int Set_Param_Capture_Centroid(int iFrames,FRAME_DETAILS FullFrameSize);///***************  im trying to pass my typedef struct by reference  instead of by value
                                FRAME_DETAILS iFullFrameSize)///***************  im trying to pass my typedef struct by reference  instead of by value
     HRESULT hResultCheckStatus =0;
     //This function is getting the number of frames configured
    hResultCheckStatus=AutoEOD_ISetupSetDefaultParam(g_hAppObj,&g_usComError,iFrames);
     if(hResultCheckStatus!=SUCCESS)
         return SUCCESS;
    hResultCheckStatus=hrCheck(hResultStatus,__FUNCTION__ ", ISetupSetDefaultParam");
     if(hResultCheckStatus<SUCCESS)
         return FAILURE;
    if(g_hAppObj)
        double dPosX = 0;
        double dPosY = 0;
        long lIntensity = 0;
        long lMean = 0;
        long iNewPosX=0;
        long iNewPosY=0;
        //Declaring and initializing framegrabber
        AutoEODType_AutoEODSensor sensor1 = AutoEODConst_AEOD_Sens_IR1;
        //Gets the full framesize
        //Trim size in half
         iNewPosX=iFullFrameSize.WidthCoordinate/2;///***************  im trying to pass my typedef struct by reference  instead of by value
        iNewPosY=iFullFrameSize.HeightCoordinate/2;///***************  im trying to pass my typedef struct by reference  instead of by value
        //Waiting for complete initialization of AutoEOD software
       Wait_For_Complete_Init_Of_AutoEOD();
        //This function receives a point and locates the nearest hot zone
        //which is assumed to be the centroid
        hResultCheckStatus = AutoEOD_ITest2MeasCentroidStart (g_hAppObj, &g_usComError, 1,
                                            iNewPosX,iNewPosY);
       hResultCheckStatus=hrCheck( hResultStatus, __FUNCTION__ ", ITest2MeasCentroidStart");
        //This Functions gets the centroid results
       hResultCheckStatus=AutoEOD_ITest2MeasCentroidResults(g_hAppObj,
        &g_usComError,
        &sensor1,
        &dPosX,
        &dPosY,
        &lIntensity,
        &lMean);
             return FAILURE;
       hResultCheckStatus=hrCheck( hResultStatus, __FUNCTION__", ITest2MeasCentroidResults");
        //Calculates the x and y offsets and stores the values to a text file
       hResultCheckStatus=Calculate_Off_Set_Centroid_Point( dPosX,
        dPosY,
        iFullFrameSize    ///***************  im trying to pass my typedef struct by reference  instead of by value        );
Message 1 of 9
(5,361 Views)
You should be able to pass a struct by reference by using a pointer to it in the function definition and and the indirect component selection operator '->' instead of the direct one (dot):
int Set_Param_Capture_Centroid (int iFrames, FRAME_DETAILS *FullFrameSize);
iNewPosX = iFullFrameSize->WidthCoordinate / 2;
iNewPosY = iFullFrameSize->HeightCoordinate / 2;
Message Edited by Roberto Bozzolo on 12-21-2009 08:52 AM
Message 2 of 9
(5,358 Views)
so this  -> by reference?
Message 3 of 9
(5,352 Views)
This operator is to address individual elements of a struct known by reference.
Message 4 of 9
(5,348 Views)
 this is the error im getting
 340, 36   Left operand of -> has incompatible type 'FRAME_DETAILS'.
             iCurrentFrame->WidthCoordinate=atoi(g_sInstrData[FRAMEWIDTH]);
             iCurrentFrame->HeightCoordinate=atoi(g_sInstrData[FRAMEHEIGHT]);
Message 5 of 9
(5,346 Views)
Where and how is iCurrentFrame defined?
Message 6 of 9
(5,331 Views)
typedef struct
} FRAME_DETAILS;
ok this is the starting point with the struct.
this is how it is define         FRAME_DETAILS iCurrentFrame={0};
then i use it in this function below
long Send_DAS3000_Command(char *sCommand)
             iCurrentFrame.WidthCoordinate=atoi(g_sInstrData[FRAMEWIDTH]);
             iCurrentFrame.HeightCoordinate=atoi(g_sInstrData[FRAMEHEIGHT]);
           //Configure the frame count and capture the Centroid.
              //Within this function we are calculating x and y offsets
              iErrorFlag = Set_Param_Capture_Centroid(iNumOfFramesSelected,&iCurrentFrame);
Message 7 of 9
(5,322 Views)
I cannot see a "->" operator in this code.
Are you sure this is the code that generated the error you sent before?
The struct is not passed into the Send_DAS3000_Command function by reference here, it looks like it is a global.
The code you sent looks irrelevant with your question.
S. Eren BALCI
IMESTEK
Message 8 of 9
(5,319 Views)
I don't understand what you are doing!
The framework should be:
  1. Define the structure somewere in your code
  2. Define a variable of type 'your structure' inside a function. Use it within that function with traditional '.' operator to address individual structure fields
  3. Pass a pointer to the structure to another function (this is normally done in order to get back some values from the called function in the structure variable)
  4. Use '->'  operator inside the second function to manipulate structure fields
  5. When the second function returns, you will have the new values available in the structure variable
From what you are saying it seems to me that you have defined your 'iCurrentFrame' variable as global to the project or at leas to the .c file (it is not defined withint Send_DAS3000_Command function where it is used). If this is the case, you do not need to pass this variable at all to any function, since all functions will see this variable and will be able to modify it. And you will always use normal '.' component selector.
If this is not true, please explain more clearly your environment.
* Edit: ebalci was faster and briefer than me! *
Message Edited by Roberto Bozzolo on 12-21-2009 02:53 PM
Message 9 of 9
(5,318 Views)
